Whats the difference in these 2 engines?
92 chevy 2wd truck 305 roller vs 88 pontiac firebird 305 roller? whats different as far as internals? the reason i ask is... wont the firebird ecm have problems if the truck engine is installed and the truck engine has different cam/ hence didnt the trucks come factory with rv cams? i know there wasnt much else different but i think the trucks camshafts had a different duration and timing advance curve was somehow differently mapped in truck ecm right?
Re: Whats the difference in these 2 engines?
I have the engine from the truck sitting in the garage with the intake off. I couldnt believe it either. But low and behold, roller lifters, rockers (looks to be aftermarket rockers) cam is stock GM cam. wish I knew where to get a grind number. that would be telltale sign. This engine ran VERY strong in the truck when it was removed. The guy that gave it to me replaced it with a blown 383. but, if i replaced the worn out block in the firebird with this one.... would i then run into problems with the computer...? i know a 305 truck computer wouldnt work in the car, so why would a 305 engine work in the car, i cant see the difference.... other than maybe the cam, and aforesaid... maybe even the throttle body.. but their cant be much else. right?
Transmission: 4L80E/4L80E
I'd guess it wasn't the factory engine in the truck, then.
Most likely it will run just fine with the f-body ECM unless the cam has been changed out for something with a lot of overlap.
good deal. it looks like a good engine. very clean internally. no sludge. no play in the mains or rods. no play (as far as i can tell) in the wristpins. great compression before i pulled the heads for an inspection. piston tops look awesome. flat top. didnt think GM produced engines with flat tops, but... compression was well into 155# steady. into the exhaust manifolds, barely any carbon to speak of, as well as in the intake manifold, near and around the egr. I called the guy a few mminutes ago asking where he bout the motor he said from GM performance and even has the original receipts. $2600 for a 305 sounded kinda high to me but i guess its par for the course huh. it came with records as well, so ill post more as soon as i get the details in the paperwork. i want to keep the car as stock looking as possible but im so tired of getting my **** kicked by these damn kids driving these hundred dollar ricers with $20 intakes and bumblebee mufflers. all i can say is.. i miss my '70.
