Oil pan size
Old Aug 12, 2008 | 06:24 AM
310IROCZ's Avatar
Oil pan size
do third gens have a diffrent oilpans than other one piece SBC's I have a 87 iroc with 89 one piece l98. need a oil pan and just want to make sure it fit when i go to drop it in the car.
Old Aug 12, 2008 | 12:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Oil pan size
I think certain trucks have larger pans. Other then that, no, I don't think it's anything special.
Old Aug 12, 2008 | 12:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Light duty trucks use the same pan. You have to get over 1 ton to start seeing differences.
Old Aug 12, 2008 | 12:47 PM
310IROCZ's Avatar
Re: Oil pan size
Thanks, i just wanted to make sure that there was not a smaller sump to clear the K member or for ground clearance.
Gunsbee
Sep 7, 2015 07:10 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
