305 swapping cars!
Old Aug 14, 2008 | 03:25 PM
durrettcustoms's Avatar
305 swapping cars!
Hey guys i have a 1983 firebird s/e with 5.0 carb engine. I am removing the engine and putting it in a 69 camaro. I want to remove all emissions and not use the pc is this possible? If not can i use the pc without emissions? Thanks!
Old Aug 14, 2008 | 03:35 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
Re: 305 swapping cars!
technically yes, you can swap the engine and if you dont use the pc you will need another carb (if its comp controlled) and a vacuum distributor
if its comp controlled and you use the pc you will be better off
you can remove the a.i.r. system and even the cat and it might pass emissions depending on how picky they are, if it needs to pass for a 69 camaro standard then you can remove everything, but if it needs to pass for 83 305 standard then put a cat on the 69 and you can still remove the a.i.r. system
Old Aug 14, 2008 | 03:38 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Not to affend you by any means but why would you put a very detuned 305 into a 69' camaro
Old Aug 14, 2008 | 03:42 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
maybe its got that straight six in it, would be an upgrade on hp but i think that six has more tq. fuel economy would be the same i think
jhawkeye
May 25, 2022 06:33 PM
Brcharrelson
Aug 26, 2015 07:47 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
