Opinions on my 383 build
Old Aug 14, 2008 | 11:29 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I've got a 91 L98 block punched 30 over, lunati sledgehammer stroker crank, 5.7 crower sportsman stroker rods, SRP forged flat tops, AFR 195 Eliminator with 75cc chambers, and a crower hydraulic roller cam spec'd out at: 273* 284* advertised 221* 230* at .05 114 lsa .530/.550 lift, and a set of 1.6 roller rockers. So im guessing I would be in the neighborhood of .570 lift.
The intake is a edelbrock tpi base, with a set of lightly ported slp runners, and a ported plenum. Im debating weather or not to go with the stealth ram. I've got a set of 24lb svo injectors but I have a feeling they arent going to cut the mustard.
Any opinions or thoughts on what kind of #'s this combo might put out?
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
Jlanz55
Sep 8, 2015 11:28 PM
TheExaminer
Sep 7, 2015 08:34 AM
