Coolant Temp sensor for ECU
Old Aug 15, 2008 | 09:52 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
I'm in the process of converting to fuel injection and I'm figuring out all the sensor locations. My question is regarding the coolant temp sensor and its location. My intake is sorta custom and right now there is not a place for on the coolant crossover. I was going to put it in the head where the fan switch would be. I guess the key to the location is proper coolant flow. I'm concerned that if I put it there it might be in a stagnate area, although with it in the head would it be a more accurate reading? If not I can make a spot for it on the manifold. Would taking a reading from the coolant passages in the head give a more accurate reading to the temperature?
Thanks...
Old Aug 15, 2008 | 01:20 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Coolant Temp sensor for ECU
you sound like you get very technical
find something else to work your brain because it does not matter as much as you think
get into porting your heads. it sounds like you have the mind for it
do you have the hands though
Old Aug 15, 2008 | 01:48 PM
Car: 1986 Iroc
Engine: Afr 408
Hahahaha. Thanks, yea I guess I'm fairly technical. I'm an ME, so technical by nature. Maybe, I'll setup a couple test probes at various locations in the cooling system to monitor temp. Maybe.
Not going to touch the heads, they're AFR's, should be good to go. However, I did port the Vic Jr.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
