rear
Old Aug 15, 2008 | 11:40 PM
CroakMan's Avatar
rear
is a 411 rear good im not gonna be racin alot jus maybr sometimes
Old Aug 15, 2008 | 11:54 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: rear
Need to know more about your setup. More than likely a 3.73 will be fine, but a 4.11 may be better. What rpm would you like to be at going through the traps(peak hp rpm), what mph will it be doing there(rough rwhp and weight), future plans, and do you care at all about street manners?
Old Aug 16, 2008 | 03:46 PM
CroakMan's Avatar
Re: rear
the motor i picked out is a 327 325hp im gonna use a 700r4 trans i got street manners like i said i wont be beating the hell out of it i migght punch it every now and then
the other stuff i didnt understand wat u mean
Old Aug 16, 2008 | 05:58 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: rear
Really, the 1/4 mile is the only reason to gear a car. The idea is that you want the motor right around peak power just as you finish off the 1/4 mile. For a properly geared car with a proper torque converter, you'll have 10% converter slip. Using 1.1 for the trans. gear ratio, your axle ratio, and tire height you get the rpm at whatever speed you're doing through the traps.
That being said, I'd say 4.11's would be better for the track, but not quite as good for the street. How about some hard numbers so you can decide which you like more. These rpm's could go up or down 100 or so from tire height:
4.11's @ 100mph WOT= 5700rpm, @ 50mph in OD= 1800rpm
3.73's @ 100mph WOT= 5200rpm, @ 50mph in OD= 1650rpm
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
