over heating problem
Old Aug 16, 2008 | 02:42 AM
mjrad's Avatar
did a pressure test ,it holds .
finnally got her running againe ,
did the head gasket ,intake gasket and it still overheats.
temp gos up to the red and after a few moments itr will go down,
when i pull over and check its seeping out of the res
fan does come on ,also installed new relay
the only thing i can think of is testing the switch,
would any one know the right precedure for testing a fan switch
thanks
fan will not come on when it heats up fast,
but when it comes on its too late ,and boiling over but temp gauge goes back down .
Old Aug 16, 2008 | 05:55 AM
Scramby's Avatar
Car: 1986 IROC-Z
Transmission: Automatic
Axle/Gears: 2.73?
Re: over heating problem
thanks
The switch should be linked with your A/C, if you have it. So, turning on your A/C should automatically trigger the fan, if I'm not mistaken.
I'm sure you probably covered these, but, just to cover the bases.
Have you checked to make sure the thermostat is working? Try checking/replacing it and see if you still overheat.
Have you verified that your water pump is working properly?
Have you checked timing? Timing can cause a car to overheat too.
Good Luck!
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
chazman
Aug 22, 2015 02:01 PM
