Starting problems . HELPPP
Old Aug 17, 2008 | 10:32 AM
89FormulaMan's Avatar
I have an 89 Formula 350 TPI
car has new cap, rotor, ignition module. plugs and wires not that old at all. also have new fuel filter.
when I wake up in morning to start car, it starts strong, immediate and quick. if i were to shut the car off 4 seconds after it idles (example), and then try to restart, it wont start. it just cranks. I have to let car sit for a while to have it restart. Whether car is hot or cold, wont start. I hear the fuel pump engage when the car starts and also when car does not start.
I tested spark between coil and cap as well as between cap and plugs. The first start after a long sit will always start the car. Need any assistance that anyone can offer.
Old Nov 9, 2008 | 10:51 AM
Greygoat's Avatar
Re: Starting problems . HELPPP
You and I must own the same car, i have same situation
Old Nov 10, 2008 | 08:03 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Pull the plugs out when this happens? Are they wet with fuel?
Old Sep 8, 2009 | 04:03 PM
Big Dog Chevy's Avatar
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
Man did anyone figure this out cause this is driving me crazy. What is causing our cars to do this.
Old Jul 27, 2010 | 08:17 PM
fuel injectors
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
