1.6 rollers not center ???
Old Aug 18, 2008 | 08:26 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
ok i just picked up a set of 1.6 roller rockers, i have the rite studs in but the roller tip is not center on the valve, its more on the 1\3 top of it. is this because of the ratio or is there any other reason? i want this done i got a dyno day to go to on saturday
Old Aug 19, 2008 | 04:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 1.6 rollers not center ???
Sounds like your pushrods may be a tad on the long side.
Old Aug 19, 2008 | 09:20 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
you might have got the 60/40 spaced rockers.
what heads do you have? if you have the AFR 227's they need the offset, so if they were the non offset ones, you might have that issue as well.
shoot us a part number...
Old Aug 19, 2008 | 05:45 PM
5.0slayer's Avatar
Car: 91 camaro RS
the heads are 963 aluminum heads, they have angle plugs and punched out to 2.02\1.6, ported and polished, the rockers are harland sharps, 1.6 i got them for 100 bucks from a guy that built a car and sold it after striping it, never dorve it
buy the way what exacthl changes on the rockers for the different ratios, you would think it would b the pivot point, witch would set the roller a lil forward, i bouight them used so they might b ford, and i caller summit and another speed shop and they said there the same just diff part numbers,
Old Aug 19, 2008 | 06:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Anyway for you to post pictures? Is it only on the intake valve?
Old Aug 19, 2008 | 07:34 PM
5.0slayer's Avatar
Car: 91 camaro RS
i could take some but currently its not all set as like valve lash and thinhg, and come to think of it would setting that cause it to draw back any?
and i havent compared intake and ex yet ill look and get back to you
PurelyPMD
May 5, 2016 04:57 PM
skinny z
Oct 5, 2015 06:23 PM
Eric-86sc
Sep 28, 2015 11:37 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
