bad luck...is my engine can be toast.
Old Aug 19, 2008 | 06:07 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
Thing like this happend....but when I installed my rocker, when strait to the track on a trailer put the car on the track, first run car is slow but not that bad.....thinking of low fuel pressur about 3psi raise it to 7psi go back.....now the car is realy slow. Back to the pit, i ear this ticking in the top, remove my valve cover...... 4-5 loosen up rocker and a missing pushrod, finaly a lifter got out...pusrod hurt the cam maybe because she was in the lifter hole.
anyway...was lucky enough to put it back up....car ran normaly and even really good....normaly run 12.50 on cold engine....and was running 12.30 on hot temp
my main question did the engine lost alot of oil pressure and is there a chance my bearing could of been damaged, because of the lost lifter??didnt think to look at it will cruissing down the track
Seb
Old Aug 20, 2008 | 05:56 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Re: bad luck...is my engine can be toast.
anyone??? just want to know if oil pressur drop alot when a lifter leave the hole
thanks
Seb
Old Aug 20, 2008 | 07:12 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
thanks
Seb
it will
Old Aug 20, 2008 | 07:25 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Not to be rude but I can't tell what you are saying or asking.
Old Aug 21, 2008 | 01:25 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
He's asking if he might have ruined a bearing due to losing a oil pressure. the answer is yes, it is possible..it just depends on how long it went without oil and if there was enough residual oil to keep it lubed for those few runs. If you start it up and it seems to be running well, I say leave it because the only way you'll know for sure is to tear down the engine to physically check the bearings.
Old Aug 21, 2008 | 06:03 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
ok good to know.....it run about 1mile.....well cruising down the track and back to the pit...then I might not hurt it that much, im running with some teflon additive maybe this saved it
thanks for answer....so only time will really tell since the car is running well for now
Seb
Old Aug 22, 2008 | 03:18 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Seb
Yes
89GTAOz
May 16, 2020 09:31 AM
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
