305 Trans Am help
Old Aug 21, 2008 | 12:19 AM
jimc1987's Avatar
Car: 1987 pontiac trans am
Transmission: 700 R 4
305 Trans Am help
I just had the tps sensor replaced and the codes were cleared well my proplem is that it runs great but a little bit after i ran the car it started flashing a code 22 again the car runs great what could be the problem i beleive it got tuned right cause a shop did it. (one of those spur of the moment things that had to get done right away could of saved me money if i did it myself lol) Anyway anyone got any ideas the car is a 1987 trans am with a 305 TPI any ideas you guys got would help
Old Aug 21, 2008 | 01:58 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Re: 305 Trans Am help
Since you have replaced the TPS and still get a code 22 it may be possible the TPS needs adjusted. Also check the ECM connector
Old Aug 21, 2008 | 08:40 AM
jimc1987's Avatar
ok i will try that either today or tom i let ya know how it goes
also will it hurt the tps if the car is being driven
Orr89RocZ
Apr 25, 2016 08:28 AM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 6, 2015 09:03 AM
Leggman1
Aug 6, 2015 04:15 AM
