5.0 TPI Morning Question
Old Aug 21, 2008 | 07:23 AM
JCherwien's Avatar
Car: 1984 Autoform Firebird
Engine: 2.8l V6
Greetings!
Back with another question on my brother's 5.0 TPI T/A.
Most of the previous issues he was having with it have been resolved with replacing the computer and PROM. However, now there's an interesting extra piece that may have been there the whole time, or just now decided to pop up.
First time the car is started for the day (Or after sitting for 6-7 hours) it will run normally for a while, then the check engine light will pop on, and it will have a hard time accelerating, and almost sounds like it's back firing when it tries to go above 2k RPM. If it's allowed to just idle, the car will stall out and die, but will continue to run if the throttle is "babied". If you stall or shut it off for around 5 minutes, and start it back up again, it will run normally and seems to run in perfect shape.
When I flash out the codes, it gives me 42 and 43.
Any advice would be greatly appreciated.
Thanks!
Miah
Old Aug 21, 2008 | 08:41 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: 5.0 TPI Morning Question
http://gmtips.com/3rd-degree/dox/tip...es/code-01.htm
Old Aug 21, 2008 | 08:58 AM
JCherwien's Avatar
Engine: 2.8l V6
Thanks - The TSB on the Bugged PROM that was in there was very helpful - I'll check that out and see if that takes care of it.
Just incase though - any other suggestions?
Old Aug 21, 2008 | 11:08 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
this is the tech article on IAC and TPS adjustment, either one could cause similar issues.
https://www.thirdgen.org/tpimod2
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
