How to do a compression test?
Old Aug 22, 2008 | 03:15 AM
BladeX10's Avatar
Car: 1991 RS v8
I'm finally going to go buy a compression gauge tomorrow. Before i even put another cent into this car.. I want to run a compression test and see if my rings are shot or if i got a messed up gasket. Problem is.. I dont know what to do.
What would be the proper way of doing this? I got all the plugs out so far. What PSI is considered good? Tell me all i need to know about this.
Old Aug 22, 2008 | 04:24 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: How to do a compression test?
There is no magical psi number that you are looking to achieve. Technically they're all supposed to be within 10% of each other.
With that said, i've seen an engine with 120 psi (what I consider low) run fine and burn nothing.
Do the test with a fully charged battery
Throttle blocked wide open
Ignition coil completely disconnected (ask me how I know)
and obviously with the tester screwed into a port.
Ideally the engine is supposed to be warm.
Start cranking. If needed, have another person watch the gauge for the initial compression spike. Higher is better. Crank till it rises no more. Record the number. Move on.
If you have some low ones pour some engine oil into the spark plug hole and re-test that cylinder. If it goes up...rings. If it stays about the same...valves or hg.
Compression tests are useful but a leakdown tester is the best.
Old Aug 22, 2008 | 10:30 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
If you have a card for the cam, you can use a calculation to figure out what psi it should read. It just all depends on compression, cam profile, bore, stroke, rod length, and altitude. Here's a calc. if you like: http://www.rbracing-rsr.com/comprAdvHD.htm Has always worked for me; says I should be 91psi, and I get that as an average.
Old Aug 22, 2008 | 07:10 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
You'll have tons of fun screwing that tester into the rear plug holes too!
Old Aug 22, 2008 | 07:28 PM
BladeX10's Avatar
Car: 1991 RS v8
I know i got my work cut out for me. Lol. I got pretty big hands.. so getting there trying to unscrew the plugs was enough work.. Also cut my hand a few times too
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
