Weak Spark, no start
Old Aug 23, 2008 | 09:40 PM
JerzyIroc's Avatar
So the other day i was driving and noticed the tach stopped working. a day or too later i noticed the car was running like crap. and whenever i floored it you can hear it breaking up. i parked it and tried to turn it back on a few minutes later and it wouldnt start. im getting spark from the coil but its extremely weak. i just put a new coil and its doing the same thing. the coil is getting power. what the hell could it be? im so stuck.
\1987 iroc 350 tpi with external coil.
Old Aug 23, 2008 | 10:31 PM
firebirdman's Avatar
Car: 89 Firebird Formula
Engine: 305 tbi
Axle/Gears: 10 bolt 3.42
Re: Weak Spark, no start
i would start by checking if the spark plugs are gaped properly, and see if your plug wires have any cracks, or spots where they have been melted by the manifold or anything that would cause a short. Also check if the distributor cap has any corrosion. Just remember when removing the distributor cap, lable the wires so you can get it back together properly.
Old Aug 23, 2008 | 10:34 PM
JerzyIroc's Avatar
i took the wire that goes from the coil to the distributor and checked the spark. there was almost no spark. you can barely see any spark. so its not really th eplugs, its the coil itself thats not giving the right amount of spark. i changed the coil and its still sparking weak. i dont get it.
Old Aug 23, 2008 | 10:51 PM
bigboy123's Avatar
make sure the balancer/timing tab is correct, check the distributor, check your grounds, ECU, and timing belt...
hope this helps...
Old Aug 24, 2008 | 08:09 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
like bigboy said, check grounds.
also pull off the dizzy cap and see that it looks like.
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 19, 2015 12:07 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
