coil arcing help please.
Old Aug 25, 2008 | 06:30 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
My car just died with no warning at a red light last night.Pushed it into a gas station and couldnt get it to crank.Tried some starting fluid and still wouldnt crank so I checked for spark and had none.Checked all over the dis. cap and all looked ok.So I got my stock coil and put it on and started right up,but it was arcing out of the plug tower.I figured it got damaged somehow in my garage so I bought another oem stock replacement and it`s still arcing.Whats the problem.Tried a new wire and same thing.That was the third msd coil in the past 4 or 5 years.A bad wire somewhere?little help please.
Old Aug 25, 2008 | 07:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: coil arcing help please.
Bad wires, bad plugs, or a grounding problem.
Old Aug 25, 2008 | 07:21 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Ok.I`ll start with some wires and plugs.I put a plug wire on the coil that completly covers the tower plug.It`s no longer arcing but If I hold my finger about an inch or so away it arcs to my finger,slightly.Is that normal?I dont know how the plugs could be bad cause I just pulled them to read them the day this happened.I removed the valve covers also to check the rocker arms cause I have a tick under load but not during Idle.Think it`s just an exhaust leak.I was wondering if I messed with something when i had the valve covers off.I checked the grounds on the back of the heads the best I could.
Old Aug 25, 2008 | 07:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, that's not normal. Are you sure you've got the wires clipped onto the plugs fully?
Old Aug 25, 2008 | 09:57 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Didnt think that was normal,never seen it before.Just double checked them and they look fine.Started touching some of the other wires and a couple of them would gimmie a little shock.Went to advanced and they didnt have the ac delco 8mm in stock and I`m not spending the money on accels and the like for the same thing.It was getting late so I`ll get some tomarrow.Guess I`ll go down the list and hit the plugs next,cap and rotar last.By reading my plugs i found I could go one heat range colder.
Old Aug 27, 2008 | 03:39 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Only a few shocking wires can be an indicator of bad plugs there, or a break in the wire near the plug.
Old Sep 14, 2008 | 01:02 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I traced it to one bad plug wire.Replaced it and car runs perfect.Seems a little odd one wire went bad and caused all this.Wire had a lot of carbon in the boot.Ran near the headers,maybe the heat caused it.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
jaridjohn
Oct 5, 2015 07:01 AM
