2-Bolt to 4-Bolt Conversion
Old Aug 26, 2008 | 09:14 AM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Has anyone ever converted their 2-bolt L98 to a 4-bolt? Or, does anyone know if there is any info out there on the proper way to do it. I don't want to risk cracking my block or bearing caps.
Old Aug 26, 2008 | 09:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 2-Bolt to 4-Bolt Conversion
Hello Michael.
You should probably go with the splayed 4 bolt conversion, as it'd be virtually the same price, but offer more strength.
Any reason for you to do this upgrade?
You do need a machine shop to do this. They will bolt in the new caps, drill and tap the holes, and line hone the block.
Old Aug 26, 2008 | 10:16 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
its a machine shop will do it and its not the cheapest thing but its not outrageous either...bottom line is u have to ask yourself do you need it? a 2bolt block with arp main studs can hold 400-450 hp no problem unless uare going to be making over about 500hp or more its a waste of money IMO.
Old Aug 26, 2008 | 10:43 AM
Engine: SBC 350
The reason I'm inquiring, is because I just bought a used L98 from a guy. It came out of a 91 GTA, and the guy had some work done to it. He had the heads ported out, and installed roller-rockers along with a Comp 306 cam; 229/245, .510/.540
I want to throw a 383 stroker kit in it because the bottom end has about 120K miles on it. I just want to make sure that it will hold up.
Old Aug 26, 2008 | 10:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A conventional straight-drilled 4 bolt block isn't significantly stronger than a 2 bolt block in any way that's going to make a difference.
You could machine it for splayed 4 bolt caps, but you don't need it.
Old Aug 26, 2008 | 11:59 AM
Car: 1991 Z28 1LE
Transmission: 4l60e
yeah just have it built with good quality ARP fasteners. it will hold up fine. ure not gonna be making rediculous power with it the 2bolt will hold....
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
