ZZ9 CAM SHAFT
Old Aug 29, 2008 | 06:02 PM
RED PIG's Avatar
ZZ9 CAM SHAFT
ZZ-9 HydraulicRoller:
Advertised Duration 282/ 287\ Duration at .050 212 /226
Gross Lift .483/.520
Lobe Separation 110
This is the cam shaft that I have in the 1986 Camaro that I purchased with a TPI system and am making into a drag race car, I am making it a carb car with a victor jr. style intake. Does any one know the power curve for this cam? At what RPM is the peak HP and torque?
Old Aug 29, 2008 | 08:52 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: ZZ9 CAM SHAFT
That's a pretty tame cam for drag racing, I'd say peak hp at 5500-5800rpm. It should have no problem off the start or need any kind of stall converter.
Old Aug 31, 2008 | 01:47 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: ZZ9 CAM SHAFT
With a dual plane, and good heads you would be lucky to get 350 hp at 5,000 rpm's. Definately not what your looking for.
Old Aug 31, 2008 | 03:43 PM
RED PIG's Avatar
Re: ZZ9 CAM SHAFT
What would be a good Hyd. roller cam for the car. And can I use the roller lifters that I have in the motor now? I have a set of world products heads on the car now but I do not know which ones the are and also I do not know what springs are on the heads. I was going to use a single plane intake on the car with a 750 DP Holley.
Old Aug 31, 2008 | 06:52 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: ZZ9 CAM SHAFT
I'd say intake cam duration of 225-235 @ .050" would be a street/strip cam. If you're really looking for power and not concerned with street, I'd go with something around 245-255 intake duration @ .050. I'd stay with a dual plane intake like the rpm air gap unless you plan either to use a big cam or put in a big stall converter. Maybe as an example: I used a 246/254 dur @ .050 .558/.558 cam with my trick flow heads on the 383 that ended up making 405rwhp @6400rpm and ran a best of 11.44 in my car.
Jorlain
Oct 8, 2015 01:57 AM
dbrochard
Oct 3, 2015 12:43 PM
88rscamar0
Sep 23, 2015 09:08 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
ericjon262
Sep 11, 2015 06:07 PM
