Fuel Pressure Gauge: Reccomendations?
Old Aug 31, 2008 | 12:02 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I am looking for a nice fuel pressure gauge that installs INSIDE the car. The ones that attach directly to the fuel rails look very stylish, but I'd be a bit more inclined to have one where I can constantly monitor it. No telling what kind of little quirks might try to hide as soon as you pull over and pop the hood.
Any suggestions? I take it these hook in place of the schrader valve on the fuel rails the same way the direct fit ones do?
Old Aug 31, 2008 | 06:44 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Fuel Pressure Gauge: Reccomendations?
I believe there are "rules" about running combustibles into the drivers compartment. Maybe they're track specific but it's still good practice to not run gas inside the car.
I'm using an electronic fuel pressure gauge. More specifically I have the Nordskog digital display gauge that mounts in an A-pillar pod.
In order to make it work I had to cut the front fuel crossover tube on the fuel rail, weld in a block that was tapped for the fuel sender module, and then wired it up from there. It all fits underneath the plenum. It's out of sight, no fuel in the pass compartment, and I still have access to my schraeder in case I feel like hooking up my mechanical gauge.
Old Aug 31, 2008 | 08:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can use an electric gauge, or you can use any mechanical gauge you want with an isolator.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
