89 Formula 350 electrical parts issue NEED help!
Old Aug 29, 2008 | 11:10 PM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
Here's the abbreviated version... Cooling fan bypassed and hot wired, quits running sometimes, when it does it pulls mega-voltage, and takes the power windows and AC with it..if it goes down I can not get the air to blow at all and the window switches become skeet shooting material, if you know what I mean..it is SUPER annoying when you live in FL in the summer and can't get air from the car OR from nature, and the car wants to over heat, please help and thank you!
Old Aug 30, 2008 | 02:30 AM
the blur's Avatar
Re: 89 Formula 350 electrical parts issue NEED help!
fan motor is shorting out. better replace it before it kills your alternator.
Old Aug 30, 2008 | 03:18 PM
ok, but how does the fan tie in to the ac and the power windows? Unless its on the same circuit/fuse??
Old Aug 31, 2008 | 05:51 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Normally the fan is on a different circuit, however yours is hotwired. I would replace the motor (s) the high-resistance of siezed up motors is blowing the fuses.
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
okfoz
Mar 9, 2017 02:35 PM
1nastygta
Aug 8, 2015 07:38 PM
