305 Vortec heads... anybody???
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Ive searched and havent found anybody talk about the 305 vortec heads. I am currently running HO heads and want to upgrade. I have a set of the 305 vortecs and a set of 882's. I could have the 882's shaved to get the right cc's. Im not looking to drop alot in the upgrade but want it to be a good improvement.
Transmission: 4L80E/4L80E
Of those 3, the best money would be spent improving your stock heads. Basic port clean-up, 1.94" intake (and 1.60" exhaust if you want), with cam and exhaust upgrades, you'll be grinnin'.
Uh, which engine are these going on?
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: 305 Vortec heads... anybody???
305, Comp XE268 cam, Performer RPM, 600 holley, th350, 2400 stall now but swapping for a 3000, shorties, headman y-pipe, hooker car back. I'm also thinking about dropping the hooker and adding a bullet and dumping it.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yep, the stock heads would work great.
Throw the 882's out the window, those are the worst of the worst.
305 Vortecs would work ok, but you'd need a new intake manifold...
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 7, 2015 05:22 PM
