Just a vaccum leak? or worse?
Old Sep 4, 2008 | 04:28 PM
10secondhopeful's Avatar
Car: '84 Z28
I got a 1984 camaro z28. (carburated 350) I recently replaced a camshaft and lifters do to the stripping of intake lobes 4 and 6 (the lifters were also mess up haha) it went fine, we put the engine back together, but it doesn't accelerate worth a damn, and it backfires like crazy, at high speeds i can stomp on it and it will get up and go fairly well but if i accelerate anything above completly weak (i had traffic backed up at stop lines i was going so slow to avoid back firing) then i back fires and slows down horribly. A mechanic friend thinks its a vaccum leak, but i have a sneaky suspision its something worse, it had a leak on the exhaust manifold but we fixed it, what could this be????
help me plleeeaaassse.....
thanks
Old Sep 4, 2008 | 05:18 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: Just a vaccum leak? or worse?
is it backfiring through the intake or exhaust?
i would say it could likely be a carb tuning issue. if through the intake (carb) you are lean, if out the back you are rich. i would also check your timing advance as that could cause it.
thats what i would do first.
Old Sep 4, 2008 | 05:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds more like timing. Did you set the ignition timing with a light when you put it back together? I assume this is the stock induction/ignition set-up, did you disconnect the flat 4-wire connector to the distributor base when you set the timing?
I assume you put the timing gears dot-to-dot when you put the cam in.
Old Sep 4, 2008 | 06:05 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
did you by chance maybe put the dizzy in 180 out when you installed it
otherwise i do lean to a timing problem, hard to say without the previous ?'s anwsered
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
