How much Power can I put in my 3rd gen Before...
Car: 1986 Trans AM
before I pop a wheelie? Power is good, but only if you can keep it on the ground.
PS. a little wheelie is fine, but I don't want to be looking at the sky.
Sorry for the low flying n00b question.
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: How much Power can I put in my 3rd gen Before...
there isnt a "pop a wheelie hp/tq number" it depends on alot like suspension setup, tires, front end weight, yadda yadda yadda. you could take a modified car that lifts the front end and put the motor in the same style car but if they arent setup similar it wont pull the wheels.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There are 12 second cars that can easily pop a wheelie and then there are cars like mine running into the 9's that have a hard time pulling the front wheels. I can carry my front wheels about a foot high for about 20 feet or so.
It's all about weight transfer, torque and traction. It doesn't take much to get the left front wheel slightly off the ground on a launch but it's not going to happen with a lot of factory driveline parts.
The "looking at sky" wheelies takes a lot of work. Third gens are very nose heavy so it's not as easy as it looks.
Car: 1986 Trans AM
http://www.youtube.com/watch?v=AxzwoTobxRM
Which BTW was awesome! Just making sure the 3rd gens were prone to flight
Car: 87 IROC L98
That's an annoying video but the few that were pulling wheelies were probably all in excess of 800HP, tube chassis and back halved cars. Maybe not all but most.
Iroc8t8
Yesterday 02:06 AM
