383 short block crate engine?
Old Sep 5, 2008 | 05:04 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
so now that i am done with body work for now i would like to start looking into performance. I know heads and cams are a normal spot to start but what about just replaceing the block with a 383 crate short block. would i see a lot of hp gain or whould it be a waste of time to put old: head, cam, fuel system, ignition and air induction on a new rotating assembly? i looked on summit and the cost would be about $2000!
Old Sep 5, 2008 | 05:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 short block crate engine?
it will make much more torque and make similar hp at a lower rpmas a L98. probly peak by 3800-4000 rpms if that. Car will be a diesel truck basically, not much fun
a 383 will want new heads/new intake/new cam but ppl have done the 383 with stock TPI/stock heads. Results were not that great as expected
Old Sep 5, 2008 | 06:50 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
well there goes that idea, thanks for the input!
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
BBSDesigns
Aug 11, 2015 07:39 PM
