I need a new intake. SUGGESTIONS!
Old Sep 6, 2008 | 11:54 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
My battery is in the stock location. The otherway, there is minimal clearance between the accessories and radiator. This hot air intake is KILLING my performance. Noticeable difference between a cool motor and a hot one.
Give me some suggestions!
Old Sep 6, 2008 | 12:30 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: I need a new intake. SUGGESTIONS!
I'm still trying to figure out how you got an LT1 to work in there...
When you say the battery is in the stock location, I don't know if you mean the driver's side.
If it isn't already, you may be able to put it there and put the air filter beside the radiator like shown below. Piping it may be a struggle because of the diameter.
Old Sep 6, 2008 | 01:24 PM
BCdawg57's Avatar
What do you mean how did i get an LT1 to work? Its pretty common swap.
Yes the battery is on the PASS side. I may need to relocate. What all is involved in that?
I could take the elbow the otherway maybe if i cut off that rad hose holder, and figured out a way to move the elbow out a tad from the tb so it doesnt interfere with the alt, that would be preferable. I could just put the filter where the charcoal canister was.
What do you guys think?
Old Sep 6, 2008 | 01:41 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
relocate the battery to the back, get a battery box through summit or such or a relocation kit pretty simple i have my battery inside my passenger side wheel well, then you could do a 3 1/2" intake to go through where you battery once was and install your air filter right below that which is what im doing
Old Sep 6, 2008 | 02:05 PM
Engine: 350 4BBL
That would be even better. He still has to run lines from the A/C compressor and they will occupy the area in front of the alternator.
Old Sep 6, 2008 | 02:22 PM
BCdawg57's Avatar
where is your spare tire?
Pac J
May 17, 2020 10:44 AM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
