EGR Valve Solenoid
Old Sep 6, 2008 | 05:07 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
EGR Valve Solenoid
Does anyone know if a vacum line or anything else, attaches here?
Thanks for your help
Old Sep 6, 2008 | 05:22 PM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Re: EGR Valve Solenoid
I'm pretty sure that's a no. There should be a small piece of foam wedged in there held in by the clips. that acts as kind of a filter. I suppose to keep dirt and other junk out of the solenoid. At least, that's how my solenoid looks.
Old Sep 6, 2008 | 05:57 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Thank's, that makes sense. I didn't remember removing anything when i took it off but i just wasn't sure.
Old Sep 6, 2008 | 06:40 PM
Elthesh's Avatar
If you're interested in stuffing some piece of foam on there, here's a photo of how it looks on a new solenoid. Upper right corner you can see the foam block/brick/whatever
http://www.partsamerica.com/product_...sta/fe9002.jpg
Old Sep 6, 2008 | 06:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
YES a vacuum line goes there, two in fact. Its a dual vacuum line connected with plastic. The dual-line part plugs into that solenoid on the opposite side of your pic, and the two lines go to the EGR valve and to the port on the bottom of the throttle body.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
