What Engine is This?
Old Sep 10, 2008 | 12:27 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I got this new engine from a junkyard and the junkyard said it was out of 85 Camaro.
That is BS because the heads are center bolt so we're dealing with at least an 87.
All I know about it so far is that It's a 305cid.
The casting number is 14093627.
What year did this come out of and will it work properly if dropped into an 85?
Old Sep 10, 2008 | 12:57 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
Re: What Engine is This?
the two center intake bolts on both sides of the intake are splayed differently, edelbrock and holley both make intakes for that engine to put a carb on, or you can oval out the holes on your excisting intake and get the spacers to accomodate for the different angle, otherwise it should work fine
Old Sep 10, 2008 | 01:03 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Its a 1988 305
Old Sep 10, 2008 | 01:08 PM
Car: 1985 Z28
It's a complete engine.
This has a different valvetrain from the one that was in the car.
Wouldn't this means the ECM would need a tune?
Old Sep 10, 2008 | 01:10 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
if you carb it there's not a lot of use for the ecm
Old Sep 10, 2008 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What car (year, induction) are you putting the engine in?
I'd be concerned about exactly what engine you were sold. Pull a valve cover and get the head casting #'s as well. Most likely you got an LO3 TBI engine.
Old Sep 10, 2008 | 10:25 PM
Car: 1985 Z28
Let's assume for a second that this engine I got (I'm going to see it tomorrow) is a complete turn key engine and has a TPI setup.
Will this work properly in my 1985 Z28 minus a new flex plate (But I believe this engine already has that on it)
Old Sep 11, 2008 | 01:35 PM
five7kid's Avatar
It'll work. What induction are you planning on using?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
