Spark plug wire breakthrough
Old Sep 10, 2008 | 02:59 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
I have problem with spark plug wire breakthrough.Just looked under hood at dark garage,and there is light show at engine comparament.Few wires have breakthrough at boots and causes rough idle and high HC emissions.
My ignition setup is:MSD pro-billet distributor #8366,MSD blaster coil#8226,MSD super conductor 8.5 wires,MSD 6A ignition box,AC Delco copper plugs.Wires are one year old,and plugs are brand new.Plug gap is 0.055".Are my plug wires so low quality that they are toasted at one year old?If cause is defective plug wires,which brand wires shoud I buy next?
Thanks,
Jari
Old Sep 10, 2008 | 11:05 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Spark plug wire breakthrough
I would buy new plug wires. MSD is hard on wires. The price you pay for the extra spark.
Old Sep 10, 2008 | 11:31 PM
z 28 jari's Avatar
Engine: 385
Should I buy ACCEL 300+ Ferro-Spiral Race Wires or MSD 8.5mm Super Conductor Wires.Any difference between those two?
Old Sep 11, 2008 | 05:15 PM
Engine: 355
Either set would be good. I don't see much difference.
Old Oct 8, 2008 | 12:18 AM
z 28 jari's Avatar
Engine: 385
Promlem not solved.I have replaced plug wires from MSD 8.5 to Accel 8.8 300+,and replaced cap and rotor and new coil.Plug gap reduced from 0.055" to 0.04".I tried also whitout msd 6a box,no differece.There still breaktroug at plugs 3,7,4,8.Funny thing is that brektroughs are at same plugs that before ignition parts replacement.
If I start cold engine,there is no breaktrougs at first ~30seconds.After that there is visible spark between plug hex and spark plug boot.
Ideas???
Old Oct 8, 2008 | 07:45 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
You could always try with dielectric grease but it sounds like there may be something wrong with those plugs so try to swap them.
Old Oct 8, 2008 | 11:43 AM
z 28 jari's Avatar
Engine: 385
I have tried dielectric grease,it makes breaktrough also with that.Current plugs are AC Delco r42lts(few hundred miles driven).Previous were Champion rs12yc.It makes samekind breaktrougs with Champions also.What do you like NGK TR55IX iridium plugs?
-Jari-
Old Oct 12, 2008 | 01:17 PM
Engine: 355
Try closing the plug gap to 035.
Old Oct 13, 2008 | 12:53 PM
z 28 jari's Avatar
Engine: 385
Just swap plugs.Now there is new set Champion rs12yc.Gapped them to 0.035".Seems to work,no breaktrougs.What do you think,is it so that 0.04" gap was too much?
Thanks for help.
Old Oct 13, 2008 | 12:59 PM
10secondhopeful's Avatar
Car: '84 Z28
.04 could have possibly been to much, i've had mine gapped at .035 and has been running great
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
