vaccum 89 iroc 350 5.7 l & overheating
Old Sep 11, 2008 | 07:06 AM
mjrad's Avatar
would anyone know where the vacuum line goes from the other vacuum line that is t off right in front of the air purge tank that runs all the way up the driver side of car ,
i had thought it to go to the back of the egr solenoid ,but the diagram i have
says it should be for fuel and i cant find that ?
thanks
also car is getting too hot ,did pressure test it holds
when i start car you can see the coolant reservoir bubbleing
and its still cold ,what would cause coolant to burn off out the exhaust
would a missing runner bolt,intake gasket do this or is this strictly
head gasket /hair line crack in head's,
i was thinking about taking the intake off and just redo this gasket
and all my problems will be fixed
when i had these heads off about a mounth ago everyone told me it was very unlikely for these heads to crack so i never had them pressure checked
cant see how a compression test would tell where the coolant is comeing from so i desided not to do that
thanks
Old Sep 13, 2008 | 09:37 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: vaccum 89 iroc 350 5.7 l & overheating
head gasket /hair line crack in heads...
Looks more like you're going to have to pull the heads off again.
Have them checked for cracks this time and resurfaced.
Old Sep 13, 2008 | 06:13 PM
mjrad's Avatar
there is a place i know of right down the street ,what is a fair price to have them checked and resurfaced ,and if there is a crack in one and the other one is fine ,should they both be replaced or do i resurface the new one to ?
is there normally a balance to keep ?thanks for all your help
Old Sep 13, 2008 | 09:38 PM
Engine: 350 4BBL
If one head is to be replaced, the "new" head must be the same part number. If one gets just a cleanup milling it won't affect the compression enough to justify milling the "new" one...unless the "new" one is a used one from a donor car then I would have it checked & cleaned up too. The milling part is not expensive, like $20 bux.
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
Out-Cast
Aug 17, 2015 10:57 AM
wruiz
Aug 13, 2015 09:07 PM
mustangman65_79
Aug 11, 2015 03:17 PM
