350tpi vaccum question
Old Sep 11, 2008 | 11:34 AM
91firebird350's Avatar
Car: 91 Firebird Formula 350
Engine: TPI 350
Axle/Gears: 3:23
hey guys
i just knotice thats right or not. anyways my car idels a little off, its about 600rpm, im not sure if thats normal. i added a k&n filter and now hear a hissing noise, which u do get from those, but i think something is wrong, i swapped to stock filter back and same thing. its on the pass side only. help. thanks
Old Sep 13, 2008 | 09:18 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: 350tpi vaccum question
Originally Posted by 91firebird350
hey guys
Check to see if you didn't knock a vacuum hose off of the charcoal cannister.
Old Sep 13, 2008 | 05:22 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
idle for a 350tpi is from 450-600 in idle. the K&N filter is a TB mounted one?? im guessing bc yours is a 91 so its SD. there are really only 2 vacume lines on the TB... the one below the TB on the driver side its literally underneath the TB(connects with a 90 degree rubber end to the nipple fitting of the underside of the TB) the other is to the charcol canister and PCV system.
the hissing noise is most likely the air being sucked in through the new high flow filter... the stock stuff has silencers etc to quiet it but it also restricts flow... a good intake should be unrestrictive and LOUD! u will hear the air being sucked in even when the hood is closed... i can hear it on my 86TA and 87 formula 350. hope this helps
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
