327 specs
Old Sep 16, 2008 | 10:33 PM
hotrodhaskins's Avatar
Car: 1988 pontiac firebird
Engine: 332sbc
Transmission: th350
Axle/Gears: 10bolt 28 spline posi trac 3.73 gea
327 specs
Can anyone tell me the rod length and the crank size (small or large journal) of a 1968 327
Old Sep 16, 2008 | 11:56 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: 327 specs
mine is a 69 327
4.00" bore(now bored out .040)
3.25" stroke
5.7" rod
the pistons for a 327 are different than a 350 which has a stroke of 3.48(IIRC)
Old Sep 17, 2008 | 04:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 327 specs
'68 is a small journal 327 IIRC, '69 was the first year for the large journal 327. The stock stroke is 3.25", bore is 4.00", and rod length is 5.7"
Old Sep 17, 2008 | 07:56 PM
85TAracer's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
Re: 327 specs
I don't mean to split hairs, but I am pretty sure 68 was a change over year, where some left over small journals were used, but the new large journal cranks were also in production vehicles. I own a 68 Corvette with the original numbers matching 327 and it has a large journal crank. The only true way to know what you have is to measure...if you need to know that info you are probably rebuilding which means it shouldnt be a problem to pull the pan.
Just my 2 cents.
Old Sep 17, 2008 | 08:59 PM
Engine: 332sbc
Transmission: th350
Re: 327 specs
what is the mesurment for a large vs a small then does it help that it is a shefield corvette block
Old Sep 18, 2008 | 06:28 PM
Air_Adam's Avatar
Re: 327 specs
Large journal crank specs (click to open):
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
angel2794
Sep 8, 2015 06:22 PM
84 TA NV
Sep 6, 2015 08:02 PM
