305 tpi problem
Old Sep 17, 2008 | 10:26 AM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
305 tpi problem
i have an 87 iroc that i purchased about a year ago. sometimes it fires right up and sometimes it will just crank (no spark). i have checked and it does get power to the coil (the bigger pink wire that plugs into the coil). but the coil does not put out anything. the coil is new.. so is the cap and rotor. i was wondering if you guys think its a problem with the coil?? or for some other reason the coil isn't getting the message to fire.. ecm maybe?? any ideas on what i should be checking?? PLEASE HELP!
Old Sep 17, 2008 | 01:31 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Re: 305 tpi problem
Not sure if this will help, but this problem sounds similar to the one in the below article.
1986 chevy starting issue
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
