sensor??????
Old Sep 17, 2008 | 11:20 PM
screamingpete87's Avatar
sensor??????
there is a sensor under my plentnum that goes into the intake it has a single black wire and is hot with key on what is this and what kink of problems would it cause? It is shorting out or something i can here it it sounds like a wire is arking the top of the sensor???? is loose so i just assume this is the cause of the noise? thanks for any input!!!!!!!!!!!!!!!!!
Old Sep 18, 2008 | 11:57 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: sensor??????
TPI? Intake temp sensor probably.
Old Sep 18, 2008 | 05:03 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: sensor??????
Screws into the bottom of the plenum and has a 2 wire connection (Although it could be easily disguised as a 1 wire connection) - Intake Air Temp Sensor.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
