CAR WONT START AHHH =0!!!
Old Sep 20, 2008 | 11:51 AM
Dany89's Avatar
my car wont start the ignition wont start go o but all lights, sensors, fuel pump etc... are working. when i turn the key the ignition wont start only the fuel pump and everything starts just the motor wont!!! i changed the coil already but same problem when i turn the key it just makes like a clicking sound!!! CAN ANYONE HELP!!!! PLIZZZZZ!!!!
Old Sep 20, 2008 | 12:27 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: CAR WONT START AHHH =0!!!
when you say click do you mean like an electrical zap. is it one click or does it keep clicking. most likely your starter or maybe your batt is just low. im bout to head out to the jy right now to get a lt1 starter.
Old Sep 20, 2008 | 01:18 PM
Hazzard's Avatar
Check the battery first, turn on your lights and try to start the car. If the lights dim a lot it's the battery, if they dont it's the starter or a bad conection. Try cleaning the battery terminals and the ground connection to the engine and try to start it again. If that dosent work either the starter or seloniod is bad. I can tell you how to check them but the easy way since you ave to take it out anyway is take it to a auto parts store, most of the chains will check it for free for you.
Good Luck
On the bright side your only looking at about $70.00 to fix it at the most.
Old Sep 20, 2008 | 06:08 PM
Dany89's Avatar
IS ONLY ONE CLIK EVERYTIME I TURN THE KEY
EVERTIME I TURN THE KEY IT CLICKS 1 TIME I CHEKE M BATT AND IS GOOD(LIGHTS WORKING ETCC..)
WERE IS THE SELENOID LOCATED AT????
Old Sep 20, 2008 | 06:15 PM
Dany89's Avatar
TRANY????
WILL A 305CC MANULA TRANSSMISION FIT MY GTA??? I HAVE THE 5.7L WITH THE 700R BUT I GET KIND OF BORD DRIVING IT SO IM THINKING OF REAPLACING IT WITH A MANUAL TRANNY BUT DOENT KNOW WHICH ONE IS BEST/FIT FOR MY 350CC ????
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
