Hard starting IROC
Old Sep 20, 2008 | 02:37 PM
Redwhisper's Avatar
Car: 86 IROC-Z
Engine: 97 LT1
Hard starting IROC
My 86 IROC is starting strangly. The TPI system should allow me to start it without touching the gas pedel, but recently to get it started I have to pump the gas like a carborated car. I have changed the fuel filter, and when it starts( which it always does) it runs fine. The engine is showing no codes, so I am guessing at the problem. Any help will be appreciated.
Old Sep 20, 2008 | 03:14 PM
CamaroRider's Avatar
Re: Hard starting IROC
Do you have to pump the gas pedal to start it when either cold or hot?
Or only when it is cold?
Or only when it is hot?
Old Sep 20, 2008 | 03:59 PM
Redwhisper's Avatar
Car: 86 IROC-Z
Engine: 97 LT1
Always when it's hot and sometimes when it's cold. If it matters, I shut it off the other day, went into the store to buy a lottery ticket (you can always dream), when I came out a minute late it started without touching the gas.
Old Sep 20, 2008 | 04:12 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Check your fuelpressure and also check your injectors.
Get back with results on this. Could be leaky injectors / stuck injectors or bad fuelpressure causing this..
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
