no start
Old Sep 21, 2008 | 12:06 AM
gm hombre's Avatar
Car: 1989 WS6 GTA
no start
this is my problem, i have an 89 gta 350,when i crank it, it won,t fire,but if i spit gas in the plenum then it fires up.but if i let it sit and try again it won't fire up,i measured the fuel pressure and it reads 42 psi but then it falls to 20psi after the pump stops,is this fuel pressure regulator problem or fuel pump,what can you advise, help is appreciated,gm hombre.
Old Sep 21, 2008 | 12:25 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: no start
May be fuel pump relay.
Old Sep 21, 2008 | 05:09 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: no start
I would check the injectors. Mine would do the same thing. It wouldnt start when it sat and if you shot starting fluid in it, it would start right up. Found four bad injectors. Replaced the injectors and it fixed it. The fuel drops seems really low to me. Could be a bad fuel pump.
Old Sep 21, 2008 | 06:38 PM
gm hombre's Avatar
Car: 1989 WS6 GTA
Re: no start
fuel pump seems to me what it could be, but if the pump shoots to 42 psi and it doesn't hold wouldn't it be the fuel pressure regulator to hold pressure steady? i'm going to buy diods to check the injectors,maybe it is the injectors but i have to be certain,thanks gm hombre.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
