no timing marks
Old Sep 21, 2008 | 09:31 PM
Luda92RS's Avatar
no timing marks
So either ive gone blind... or my LO3 305 is missing the timing marks....
anyone know what to do in the situation?
or if they might be in some place other then on the main pulley?
the vehicle is a 1992 Camaro RS 305TBI w/ a 700R4 trans
Old Sep 21, 2008 | 11:11 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Re: no timing marks
I had to take a wire brush to even find the timing mark on mine. eventually i found it. I don't know about your situation though.
Old Sep 22, 2008 | 01:07 AM
Luda92RS's Avatar
Re: no timing marks
hurm... ill take a wire brush to the pulley tomorrow, but i didnt see the bracket on the pulley at all
Old Sep 23, 2008 | 05:07 PM
Luda92RS's Avatar
Re: no timing marks
double checked today, and unless ive gone blind recently then there are no timing marks...
any idea on how to check timing without them?
or how to install a new set of timing marks?
Old Sep 23, 2008 | 06:17 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: no timing marks
where are you looking for them at ? if your looking at the 2 o'clock position on the drivers side . wrong , thats where most people would look . some genius at g.m. decided to move them to 12 o'clock behind water pump . look straight down behind waterpump . hope this helps , don't forget to disconnect e.s.t. wire . good luck .
Old Sep 24, 2008 | 08:49 AM
Luda92RS's Avatar
Re: no timing marks
wait.... so the water pump is in the way?
Old Sep 24, 2008 | 09:08 AM
UNCLE TOM's Avatar
Re: no timing marks
no , waterpump is not in the way . look down between back of waterpump and front of block . you will see a metal circle , that is where the mark on the balancer will show with the timing light .
no , waterpump is not in the way . look down between back of waterpump and front of block . you will see a metal circle , that is where the mark on the balancer will show with the timing light . good luck.
Old Sep 24, 2008 | 09:37 AM
Luda92RS's Avatar
Re: no timing marks
hurm.... interesting... ill have to go investigate this shenanigans
thanks uncle tom!
Old Sep 24, 2008 | 12:42 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Re: no timing marks
yeah, straight down the middle. I used some white nail polish to keep mine visible. now, i can't lose it AND it's just so purdy.
Old Sep 24, 2008 | 12:46 PM
Luda92RS's Avatar
Re: no timing marks
Thanks a ton uncle tom, i would have never looked there.
no to dig up an image of a labeled timing mark and figure out what my timing it, i know its retarded cuz its sitting on the far right edge, but the timing tab is rusted to hell and im not messing with wirebrushing it in its position.
*edit* thanks to you as well osirus. of course once while im digging up this image i read about GM shifting the timing tab upwards.
Old Sep 24, 2008 | 12:54 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Re: no timing marks
in this picture the timing mark is already set at zero. I knew i had a picture somewhere. **example on an 86', hope it helps**
Old Sep 24, 2008 | 02:26 PM
Luda92RS's Avatar
Re: no timing marks
exactly what i was looking for. on mine it is barely lining up with the FAR right side of the right hand peak, could be the cause of my car failing emissions for HC being a touch high.
Old Sep 24, 2008 | 02:31 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Re: no timing marks
yeah, that's from way back when i was doing the valve lash
Old Sep 24, 2008 | 04:09 PM
Luda92RS's Avatar
Re: no timing marks
now i just have to get the lockdown bolt loose... joys
Old Aug 27, 2010 | 09:59 PM
geckster's Avatar
Car: 1983 Z28
Engine: 305 crossfire
Re: no timing marks
Bump!, i know this is a really big thread dig. But... how many degrees are the timing incriments on the tab? 2 degrees each?
Old Aug 27, 2010 | 10:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: no timing marks
IIRC the first peak is 4 degrees, and then each trough and peak after that is 2.
Old Aug 27, 2010 | 10:15 PM
geckster's Avatar
Car: 1983 Z28
Re: no timing marks
So, in the pic on post 11, 0 deg is in the trough, and the peak immediately to the left is +4 deg?
Old Aug 27, 2010 | 10:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: no timing marks
I believe so.
Old Aug 27, 2010 | 11:45 PM
geckster's Avatar
Car: 1983 Z28
Re: no timing marks
Sweet, thanks!
midge54
Dec 27, 2019 04:14 PM
Bryan F
Aug 18, 2015 02:28 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
