easy question
Old Sep 23, 2008 | 06:47 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
easy question
What are the cheapest heads that can be ported to flow? i already have the l05 heads but if there is another head that could be better ported for under 300 bucks than let me know.
Old Sep 23, 2008 | 07:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: easy question
The best "bang for the buck" heads out there are Vortecs.
You can find 'em in most junkyards for nothing, because they are truck heads, but they are the best flowing production-line head GM ever used on a SBC. Porting takes them even farther, especially on the exhaust side.
Only downside, is that they require the use of a 'Vortec' style intake manifold, because the bolt pattern and port locations are somewhat different from a normal SBC head. The exhaust side is the same however, as is the mounting to the engine block and all the valvetrain (though its the newer self-aligning style, unless you change that).
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BurlyChev
Aug 16, 2015 09:08 PM
