2008 Engine Masters Challenge
Old Oct 1, 2008 | 03:29 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://www.popularhotrodding.com/eng...day/index.html
The GM camp holds the lead as of now.
http://www.popularhotrodding.com/eng...tes/index.html
Old Oct 1, 2008 | 10:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 2008 Engine Masters Challenge
What am I missing here? They seem low on power... what are the limitations? I was expecting 700HP small blocks, but these are about 1.1HP/cid range... Are they only testing at 4000RPM or something?
Old Oct 1, 2008 | 12:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I dunno, I think there are some limits on the type of parts you can use to keep things fair. To many parts you can just slap on any ford or chevy to make them fast, its more down to skill of the builder. Not is credit card limit.
If you read the info below each team, on the Monday page the Buick team hit 717HP on some after test runs. Why on Tue the Olds is still in first place, Poncho 2nd.
Old Oct 1, 2008 | 02:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Rules:
http://krang.popularhotrodding.com/e...les_072108.pdf
It's average torque and HP from 2500 to 6500 RPMs.
Old Oct 1, 2008 | 03:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
Thanks Five7!
any heads (except race built heads, ie 15*, 18* etc)
any cam (flat tappet or mech tappet, no roller)
any porting.
Huh... I figured they'd be making far more power then that... weird.
Old Oct 1, 2008 | 03:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Could just be no one is intrested in it, they don't have the time or money to enter. Which I find real hard to believe, I just think there would be allot more teams in it, if its wasn't money.
Old Oct 2, 2008 | 10:48 AM
five7kid's Avatar
A few of the write-ups quote the peak HP, which will be much, much higher than the 2500-6500 RPM average. It's also more realistic than peak numbers. Since you won't do yourself any good by making power above 6500 RPMs, they're shooting for more power down low.
I believe they also limited the entries - or, put another way, only accepted certain entries.
Once you recalibrate your brain to the limitations the builders are under and how they're measuring power, you'll realize that these guys are producing some very impressive power.
Old Oct 2, 2008 | 10:55 AM
Sonix's Avatar
Car: 1982 Trans-Am
OHHHHH! I missed that little tidbit of information! Well then, that's amazing! Holy cow, i'd like to have one of those engines in my bay !
Old Oct 2, 2008 | 11:20 AM
five7kid's Avatar
The DQ's are harsh. Two 5 liter SBC's disqualified for the oil pan they had on. A Mopar for intake bolt pattern.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
