Puddle of Power Steering Fluid
Old Oct 2, 2008 | 04:11 PM
clewis's Avatar
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
So I'm detailing my car (1985 IROC-Z 305 TPI) today in my garage. When I pull it out of the garage I notice a puddle of what looks like oil on the garage floor. I start looking underneath and don't notice anything that is leaking at the rate it would have to have been in order to leave that much oil. I don't know why, but I checked the fluid level in my power steering pump and there is none. I add a little to see what happens and it begins leaking out. Is this how they bad, or is there something else I should be looking for? How difficult are they to replace? Any special tools required? Any help would be greatly appreciated.
Old Oct 2, 2008 | 05:02 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Puddle of Power Steering Fluid
Its not hard to change the PS pump, you just need to rent or buy a PS pump pulley tool, Places like autozone will lend ya one.
Just be careful when putting the new one on, my stock hose wasn't lining up just right and I stripped the thread on it. Thank god notthe thread in the new pump. Had to wait 2 more day to finish cause of that.
Only 1 hose has a threaded fitting, the other hose is just held on with a hose clamp. Factory its a non removable band but its the low pressure side and a normal hose clamp will hold it on fine.
Old Oct 2, 2008 | 09:24 PM
clewis's Avatar
Car: 1985 IROC-Z
Thanks for the reply Gumby. Is there any major concern about driving my car without power steering fluid? It may be a couple of days before I can get around to replacing the pump.
Old Oct 2, 2008 | 09:55 PM
vette gator's Avatar
Car: 85 Z28
Is it definitely from the PS pump? I had leaks from my PS pump and my steering box. Both are pretty easy to replace. I think that the PS fluid is what lubricates the gears in the steering box, so it might wear with no PS fluid. Steering boxes are around $150 - $200, so I'd hate to see you do yours in if it's OK now.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
