Race gas to Premium Problem
Old Oct 2, 2008 | 11:10 PM
89TA383M5's Avatar
Car: 89 TA
Engine: 413 TPI
Transmission: TKO 600
So was running my car on 93 octane. Then for 2 weeks i switched to 110. Had about 1 and a half gallons left of 110 in the car and put 8 gallons of 93 in the car. As soon as I left the gas station the car started missing and running lean. Changed the plugs. Oxygen Sensor looks ok. Reset Computer. Checked Cap, Rotor, and wires which were all ok. Drained the tank all the way and put 5 gallons of 93 from a different gas station and it still runs the same. Fuel injectors?
Old Oct 2, 2008 | 11:21 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: Race gas to Premium Problem
Sounds like to me that you had moisture/water in the gas and since gas is lighter than water, may still have water still in the bottom of the tank.
Could also be a coincidence that some thing is wrong with you timing/ignition.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
355tpipickup
Aug 13, 2015 07:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
