question about vaccum leak.
Old Oct 4, 2008 | 01:00 PM
91firebird350's Avatar
Car: 91 Firebird Formula 350
Engine: TPI 350
Axle/Gears: 3:23
Hey guys,
Im having hessitation problems with my car. when it gets warm she has issues at idle like she wants to stall. i know its a vaccum leak or so i think.
I did the brake parts cleaner test on all the spots i thought there might be the issue. I just read that sometimes the FPR gasket can cause this. Is this a common thing and would that cause it. When i shut the car off she seems to smell of rich fuel. I didnt hear the motor idle up either when testing it.
Should i see if there is a code or any idea's.
Where are the most common places for this to happen.
Thankyou
Old Oct 4, 2008 | 01:52 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: question about vaccum leak.
It could also be an injector stuck open.
Old Oct 4, 2008 | 06:23 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It could be a 100 different things. You really need a scanner (or PC/Cable) to see what's going on.
Old Oct 4, 2008 | 08:49 PM
Zac 87 GTA's Avatar
Car: 83 Z28
Engine: 355CI
I'm having the same issues with my 87 I'm still trying to figure out what it is could EGR, fuel pressure regulator that is what i'm trying out for now
Engine: TPI 350
Axle/Gears: 3:23
any thought or things that are most common to check first. also is there a place that has the trouble codes so when i check i can match them up.
Old Oct 4, 2008 | 09:13 PM
jv9999's Avatar
Engine: 5.7L/350
The codes are here: https://www.thirdgen.org/service-eng...ht-error-codes
Could be a vacuum leak, EGR stuck open, bad injector or two, fouled plugs, bad wires/cap/coil/distributor, tired engine (low compression), bad MAF/MAP, temp sensor, and a bunch of other things. You really need the to see what the ECM sees or you're just throwing parts at it.
Bubbajones_ya
Aug 31, 2015 12:02 PM
mike_c
Aug 27, 2015 04:32 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
