Why are all my guages off?
Old Oct 5, 2008 | 10:30 AM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
My Tach bounces all over the place, my Speedometer is way off, and my temp gauge shoots up anytime I accelerate. It's so annoying and I hate driving people and them see all my guages orgasm. My odometer is also off, it's putting more unneccessary miles on my car evertime I drive!
I wanted to do Digital Guages, for that more modern look. Should I get my gauges fixed and then do the Digital guage swap or just put them in and maybe they can fix themselves? I don't know anything about this or the why my guages are off.
Help Appreciated, Thanks.
Old Oct 5, 2008 | 10:56 AM
pandemic_ratio's Avatar
Car: 1992 RS Camaro
Engine: 350 small block V8
Transmission: icky automatic
Re: Why are all my guages off?
weird, check your temp sensors, tach wire/plug (depends on your distributor as to what it looks like and where its located.), um as for your speedo being off check the cable that goes to your transmission if its loose or maybe the gear on the end of the cable is worn out...but you might just want to go with all manual gauges, they are more accurate anyway. (at leats in my opinion) any way i hope i helped.
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
