A Couple Questions
Old Oct 13, 2008 | 02:59 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Transmission: Automatic
A Couple Questions
ok i got a couple question first let me tell you its a 92 camaro Rs. 187,000 305
1) The engine fan runs automatically but as soon as i turn the A/C on the fan quits working. If i leave the a/c off then the fan continues to run fine. any ideas?
2) the car randomly will randomly shut off while driving. Then if i crank it again it will crank on the first try. Its not overheating. And the fuels not sloshing around causing it to possible cut-off. Any ideas?
Thank you i really appreciate it
Last edited by smokenasty; Oct 14, 2008 at 12:11 AM. Reason: confused a couple of the words around
Old Oct 13, 2008 | 03:28 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: A Couple Questions
the fan is supposed to run with the ac on and can you give an more info on the second question does it jerk around when it shuts off or does it just shut off with no hesitation?
Old Oct 14, 2008 | 12:10 AM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
ok no it just shuts off with no hesitation..and on the ac thing what i meant to write was that when i turn the A/C on the fan quits working. i'm stupid but thanks
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
