idles low in drive and reverse
Old Oct 13, 2008 | 05:11 PM
Nater2491's Avatar
my car idles low while its in drive and reverse, not in park or neutral. any suggestions on what this could be ?
Old Oct 13, 2008 | 05:24 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
Re: idles low in drive and reverse
its under load....everycar does this....you dont know this????
Old Oct 13, 2008 | 05:33 PM
Nater2491's Avatar
i guess i didnt word it right, it surges . its bounces and sounds like its about to die
Old Oct 13, 2008 | 09:17 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Have you played with your timing recently, it might be a little high. Check your IAC and your TPS too. Theres a technical artical on all of these in the technical section. That will probably fix your problem and in the end your car will run better than ever too.
Old Oct 13, 2008 | 10:32 PM
Nater2491's Avatar
i have played with the timing a little bit so i will check that out
Old Oct 14, 2008 | 05:36 PM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
ohh lol....is there a recent tune up on it?
jklein337
Sep 19, 2018 06:23 PM
perZ
Aug 15, 2015 01:17 PM
mizz0313
Aug 12, 2015 06:45 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
