Starting to think headers were a bad idea
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
So I got my nice hooker headers on that my girl bought me for my birthday. They are 1-5/8th primary to 3in collector, flanged down to 2-1/4 true duals with real cats and flowmasters.
Now the car does run pretty rich but it was running very well before this. I get the install done bring it to a shop and have the connecting pieces bent up.
The car is slower, significantly. I think I hear a little wisp of an exhaust leak but could that cause such devastating performance losses?
I'm going to pull the carb and fix the leaking plugs, and lower the float level a smidge. I gotta change the spark plugs out because I know they've gotta be fouled from running rich but my point is that everything is the same as pre headers. And now its slower...
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: Starting to think headers were a bad idea
Did they reinstall the o2 sensor. Do you have a check engine light?
Its in a monte. LG9 (305) with mechanical carb and vacuum/mech dizzy.
A good question would be. Say I shifted my exhaust to be way to top end and I'm not scavenging properly for torque in the low end. What can I do to remedy this? Is there any sort of venturi that I can install into the collector?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
did you re-jet the carb after the headers were installed?
chances are you're a bit lean now.
exhaust leaks (on a mechanical car) don't cause any problems other then possibly poisoning you. Fix those just because they are annoying. No HP difference though.
if your plugs are fouled, you might have a miss under load. Swap plugs and check mixture at idle and under power.
Transmission: 4L80E/4L80E
Thats what I figured you meant. I just wasnt sure if there was sort sort of weird interference thing I didnt know about maybe.
The answer to that would be no. I checked this morning to be sure and they are all good. I was smart thhis install around and marked my wires.
I'm gonna change th plugs when i get home and see if its just fouled plugs.
Whats red and hot and smells like **** all over?
Car: 1982 Trans-Am
burnt tranny fluid?
or burnt red plug wires?
or your hands burning?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1984 z28 h.o.
Transmission: 5 speed
I don't think you need a mechanic. When I had my motor rebuilt and after I reinstalled it, my motor guy told me that crossed wires, I realize this turned out not to be your problem, can actually jump spark under the right conditions. I'm talking about wires laying across each other. This was the first time I had heard this, but to keep my warranty in order I had to wrap fuel line around my wires that crossed or came near the headers. With my wires I ended up with quite a bit of extra wire by the distributer that actually had to be bundled up so I beleive that was part of the concern. Coiled up wires with electricity in them is always bad news. I need to pickup shorter ones soon.
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
If the car clogged brand new cats instantly (unless these are your old cats), there's something seriously wrong with the setup.
New cats aren't that expensive (especially universal style, which you're probably using) add that onto the fact that you can sell your cats for the precious metals inside of them for a pretty amount of coin....
Also, most aftermarket/universal cats have a metal honeycomb. You better have an air hammer to hollow them out, I don't think the piece of rebar will cut it.
