Sucking coolant
Old Oct 16, 2008 | 05:42 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Sucking coolant
Quick question. If I use a wet/dry vac to suck coolant from the intake can I get enough out so when I pull the intake and heads it won't overflow everywhere? The plugs in the block seemed to be seized solid figured this would be another way to do it. Thanks
Old Oct 17, 2008 | 07:21 AM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Sucking coolant
Nothing? I guess it would be good to get those plugs out anyway to flush it out. I'm just trying to get these damn heads off before it gets too cold.
Old Oct 17, 2008 | 07:38 AM
FUNIROC's Avatar
Car: 1989 IROC
Re: Sucking coolant
You can get most when you open the drain on the radiator. It will help alot. I did that before pulling my intake and very samll amount of fluid was left in the intake. I had more fuel from the fuel lines then water from the engine. I am not sure about the heads, would not think much would be in them.
Old Oct 17, 2008 | 08:00 AM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Sucking coolant
First time getting this deep into sbc. When I get them off its probably going to stay that way until spring, so I didn't want a bunch of coolant getting everywhere and sitting there all winter.
Old Oct 17, 2008 | 08:04 AM
kcb37's Avatar
Re: Sucking coolant
You would be better off leaving it alone, then letting it sit that long.
You will have more rust on the inside of you engine with them off.
Old Oct 17, 2008 | 08:51 AM
FUNIROC's Avatar
Car: 1989 IROC
Re: Sucking coolant
Yeah, if you can just hold off till spring. It will save you some work in the long run.
Old Oct 17, 2008 | 02:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Sucking coolant
The inside of the engine is covered in oil, it's not going to rust.
sheachopper
Jul 31, 2019 11:27 AM
3.8TransAM
Oct 1, 2015 07:47 PM
