Installing poly locks
Old Oct 10, 2008 | 07:38 AM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
This is a newbie question but I would rather get it right...
When installing poly locks for the rocker arms is this correct:
Install poly lock finger tight
Turn poly lock 1/4 turn more with wrench
then rotate crank and run through the procedure of tightening the set screw
for each rocker arm
I read from some other engine build that they used a dab of grease on each end of the pushrods when installed. Is there a certain grease to use for this and certain kinds that should NOT be used? Any other lubricating and cleaning suggestions when installing rocker arms, purods, poly locks, etc...
Old Oct 10, 2008 | 09:35 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Installing poly locks
That sounds strange.
Make sure the valve you're on is on TDC, (EOIC or however you like), then install poly lock, to desired preload (hydraulic cam? 1/2 turn or whatever of preload), then back it off maybe 1/8", tighten the set screw, and turn both together the last 1/8 of a turn. That will lock them together like GANGBUSTERS, and they will NEVER come loose.... I rounded a handful of my setscrews last night trying to get the ba$(*%'s loose!
brake kleen would be my cleaner of choice, it self flashes off.
ARP thread grease, moly lube of any flavor, lubriplate 105 or whatever it is...
Old Oct 17, 2008 | 01:24 PM
Car: 1992 z28
I have read about EOIC and somewhat understand the procedure but as I turn the crank I am not 100% what position I am in.
Can someone help me out here. If I start at the #1 cylinder the dots on my crank and cam gears line up (one pointing up and one pointing down) - this is TDC for the #1 cylinder correct? Now I would tighten the poly lock nut hand tight, then 1/4 more turn and then tighten the set screw and move onto the second rocker arm of the #1 cylinder?
If that is correct then how much to I turn the crank to know I am ready to the intake port (exhaust is first correct then intake for each cylinder?)
If not correct, please advise me otherwise. I really appreciate the patience of those who help out here.
Old Oct 17, 2008 | 02:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need to know what position the crank is in so much with that method. You set the intake valve on a cylinder when you see the exhaust valve opening, and you set the exhaust valve when you see the intake valve closing.
Old Oct 17, 2008 | 02:15 PM
Car: 1992 z28
Where can I see these valves opening and closing? Can I simply look in the exhaust ports on the sides of the heads? Intake is already on so I cannot see much.
Old Oct 17, 2008 | 02:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You've got the rocker covers off, just watch them.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
