Emergency fuel question... Please Help!!!
Old Oct 16, 2008 | 07:40 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
OK.. I think I might have stripped the 3/8 side of the fuel rail inside.. I might have a small shot at repairing it if I new what size tap I would need... Does anyone know? Or know where I can look to find out.. I go back to the shop in the morning to finish the car, and I need it done.. Please let me know somethin.. thanks in advance.
Old Oct 17, 2008 | 08:49 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: Emergency fuel question... Please Help!!!
So, it is the intake manifold you stripped? I don't know what tap to use. Usually (Especially with aluminum) it is best to get a heli-coil. All you need for that is to take your bolt into a place that sells these. Most auto parts stores and hardware stores should have them. You can match the heli-coil with your bolt. It will tell you what tap to use on the packaging if I remember right. You tap the hole (STRAIGHT). Put a dab of red lock-tight on the coil. Use the special tool that comes with the heli-coil to put it in. Let the lock-tight set. Then you're good to go.
I did this once to a carb that had a stripped out air filter mounting stud. It was not my car or my doing. I just volunteered to help
Old Oct 17, 2008 | 11:02 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I think he actually stripped the fitting into the fuel rail. Which is bad. It's also aluminum, but I don't think it's an application you can heli-coil. You could probably TIME-SERT it, but the time-sert kit is EXPENSIVE. >.<
http://www.timesert.com/
Old Oct 17, 2008 | 08:17 PM
Copchaser's Avatar
Thanks for help guys, I forgot I actaully ahd another fuel rail laying around, So I just swapped it out.. Was just a pain diggin back into the SR setup I have, but its done now.. Thanks again
Old Oct 17, 2008 | 08:44 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
youre very welcome,jimmy
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
smooth
Aug 18, 2015 06:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
happyhapka
Aug 15, 2015 04:42 PM
