Electronic Controlled Carb/Distributor
Old Oct 18, 2008 | 12:26 AM
basiccamaro's Avatar
I've got a 1986 Z28 305 that I'd like to try and run on an engine stand just to see if it runs. It has the computer controlled carburetor that is wired to the distributor, and I assume the computer. So my question is, can I run the engine by just supplying 12V to the ignition, and supplying a ground, without having the computer wired in? Can either the carb or the distributor be used on an engine without the electronic wiring hooked up?
Old Oct 18, 2008 | 12:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Electronic Controlled Carb/Distributor
It'll start and run for testing without the computer, just don't expect much out of it for performance.
Old Oct 19, 2008 | 12:10 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
i believe the computer replaces the vacuum advance
jrdturbo
Mar 31, 2016 02:58 PM
BrianI
Oct 3, 2015 12:57 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
