Whine from rightside rear end?
Old Oct 19, 2008 | 01:55 PM
Hubbardj6's Avatar
Car: 1984 Z28
Engine: 355
Axle/Gears: stock
ok, so ive already checked the fluid in the rear end, it was good. i replaced it anyways just to make sure. theres a weird whining sound when the car is accelerating. it seems to only make the noise when im on the gas, and the sound is quieter a lower rpms, and louder and a higher pitch from around 55 up. could it be a wheel bearing? i dont know, help me out here. thanks.
Old Oct 19, 2008 | 02:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Whine from rightside rear end?
If you've replaced the fluid and checked the teeth for wear or damage and all's good, the wheel bearing may be the culprit. If the bearing is bad, you probably have a weeping oil seal as well. Look for oil inside the wheel.
JamesC
Old Oct 19, 2008 | 02:14 PM
Hubbardj6's Avatar
Car: 1984 Z28
Engine: 355
Axle/Gears: stock
Thanks alot man, its really been bugging me. ill go check it out now.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
